Taztiger4 Offline
#1 Posted : Tuesday, 13 May 2025 9:20:36 PM(UTC)
Taztiger4
Hi
Replacd modulator using factory gasket & pissing fluid between modulator & trans case.
Read somwehere not to use gasket but use an aviation type gasket goo, brown sticky stuff
anyone had similar issue ?
#2 Posted : Wednesday, 14 May 2025 1:44:16 PM(UTC)
Originally Posted by: Taztiger4 Go to Quoted Post
Hi
It could be that the modulator gasket is not leaking, that in itself is quite unusual.
There is a much more common leak nearby, where there is an aluminium plug held in by a pin. It's o-ring needs to be replaced.
The pan has to be removed to do the job. It is a task that might be beyond the skills of a DIY guy.
Taztiger4 Offline
#3 Posted : Monday, 26 May 2025 10:17:34 PM(UTC)
Taztiger4
Hi
Thanks, I fixed it, discarded the gasket & used the Loctite brown aviation gasket goo.
Worked atreat
Now the bloody thing wont hold on Park !
