Fastlane
Holden Forums
Holden Technical Talk
Holden Monaro HT 308 Choke operation
Joined: 7/02/2025(UTC) Posts: 5 ![Australia Australia]() Location: 2074 Thanks: 2 times
Hi. I'm trying to sort out how the choke works on the 69 Monaro 308 carby. Should there be a vacuum hose (or other?) connected to the choke or is it a bimetallic system. And can anyone tell me what carby it is? Thanks. https://ik.imagekit.io/2...?updatedAt=1748746070787
Thank you to member HK1837 for a description of the heating system of the TetraJet choke system. I've decided to replace the exhaust-heated mechanism with the electrically-heated unit. Now I'm wondering how to shut off the vacuum from the carb used to suck heated air in the pipe passing the exhaust pipes? Has anyone does this conversion before?
Joined: 6/07/2019(UTC) Posts: 470 ![Australia Australia]() Location: bayside Melbourne Thanks: 303 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: MonaroZA  Thank you to member HK1837 for a description of the heating system of the TetraJet choke system. I've decided to replace the exhaust-heated mechanism with the electrically-heated unit. Now I'm wondering how to shut off the vacuum from the carb used to suck heated air in the pipe passing the exhaust pipes? Has anyone does this conversion before? vac cap or plug... is what I use with electric choke conversions on Quaddies |
Originally Posted by: MonaroZA  Thank you to member HK1837 for a description of the heating system of the TetraJet choke system. I've decided to replace the exhaust-heated mechanism with the electrically-heated unit. Now I'm wondering how to shut off the vacuum from the carb used to suck heated air in the pipe passing the exhaust pipes? Has anyone does this conversion before? The vacuum source is under the carby, just above the smaller hole, look in the first pho below. Mine had that choke operator removed and a dirty Holley on it, they'd jammed a lead ball into the hole, you can see the ball where I removed it in the first photo, sitting on the carby mount face. The larger hole is threaded, a bolt holds the choke operator on. Just remove the choke operator and plug the hole with a lead ball or even a bit of Araldite or similar epoxy.   |
Fastlane
Holden Forums
