Hi fellas. im a proud owner of a nice HZ Statesman. the problem is very light power steering. is there a way i can make it more heavy feeling. Thanks
Does it have its original steering arms? Is the turning circle terrible? |
not sure about the steering arms. it has a good turning circle
I had a HQ Prem with power steering that was light, could steer with 1 finger, I didnt mind it actually.
Maybe check youre tyre pressures, they might too high, are they stock width or wider?
James |
You only have to be in front at the end of the race. |
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Try pulling the belt off the power steering pump. That works well ........
Joined: 2/02/2009(UTC) Posts: 567  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 32 times Was thanked: 9 time(s) in 9 post(s)
Another possibility is wheel alignment. HZs with power steer ran 3 deg of positive caster. If you've got negative castor, that will lighten the steerin.
Attn camry drivers. The accelerator is the skinny pedal on the right. |
It's more than likely a worn spool valve in the box.
The 'feel' of the steering is governed by the torsion rod in the valve. It is secured by a pin, which if worn (or if its holes are worn) will lighten the steering considerably.
If the wheel alignment & tyre pressure check out, then you probably just need an exchange box.
Dr Terry |
Thanks guys, the alignment is good and tyre pressures were alittle down. my car has 8inch GTS rims with a 235 tyres all round.
My HJ Statesman has really light steering too, even with 8 inch Hotwires and half flat tyres.
