Jvanner Offline
#1 Posted : Tuesday, 2 October 2012 4:50:10 AM(UTC)
Jvanner
Hi fellas. im a proud owner of a nice HZ Statesman. the problem is very light power steering. is there a way i can make it more heavy feeling. Thanks
#2 Posted : Tuesday, 2 October 2012 5:20:27 AM(UTC)
Does it have its original steering arms? Is the turning circle terrible?
Jvanner Offline
#3 Posted : Tuesday, 2 October 2012 7:37:29 AM(UTC)
Jvanner
not sure about the steering arms. it has a good turning circle
JBM Offline
#4 Posted : Tuesday, 2 October 2012 8:22:27 AM(UTC)
JBM
I had a HQ Prem with power steering that was light, could steer with 1 finger, I didnt mind it actually.
Maybe check youre tyre pressures, they might too high, are they stock width or wider?
James
#5 Posted : Tuesday, 2 October 2012 6:53:31 PM(UTC)
Try pulling the belt off the power steering pump. That works well ........
Premier 350 Offline
#6 Posted : Tuesday, 9 October 2012 6:08:25 PM(UTC)
Premier 350
Another possibility is wheel alignment. HZs with power steer ran 3 deg of positive caster. If you've got negative castor, that will lighten the steerin.
#7 Posted : Tuesday, 9 October 2012 7:22:22 PM(UTC)
It's more than likely a worn spool valve in the box.
The 'feel' of the steering is governed by the torsion rod in the valve. It is secured by a pin, which if worn (or if its holes are worn) will lighten the steering considerably.
If the wheel alignment & tyre pressure check out, then you probably just need an exchange box.
Jvanner Offline
#8 Posted : Monday, 22 October 2012 10:01:22 AM(UTC)
Jvanner
Thanks guys, the alignment is good and tyre pressures were alittle down. my car has 8inch GTS rims with a 235 tyres all round.
playwme Offline
#9 Posted : Tuesday, 23 October 2012 7:11:33 AM(UTC)
playwme
My HJ Statesman has really light steering too, even with 8 inch Hotwires and half flat tyres.
Guest (5)
