will_massey00 Offline
#1 Posted : Thursday, 17 May 2012 6:09:03 PM(UTC)
will_massey00
I have an issue with the bolt pattern on a 308 that I bought some years ago. It is supposed to be a Trimatic pattern so that I can fit a manual gearbox. The dowels and upper bolt holes line up but the bottom two are about 1/2 hole out. Has anyone known this issue before?
It obviously isn't a Turbo pattern as they are quite a lot different, and I have a couple of bellhousings and a trimatice geabox which all have the same issue, so it's not them.
Regards
Will
Dr Terry Online
#2 Posted : Thursday, 17 May 2012 9:15:10 PM(UTC)
That sounds a bit odd. Does it look like someone has maybe filled, faced & re-drilled the lower holes ?
#3 Posted : Thursday, 17 May 2012 10:19:28 PM(UTC)
will_massey00
I don't think so. I will take a few pics tonight. I would understand if the holes were elongated but they aren't.
There are only two variants right. When I bought it, from Gazza's in Melbourne, they said it came out of a ute with a trimatic. The onl thing I can guess is that the bolts were never in there!!!
Weird
#4 Posted : Friday, 18 May 2012 6:12:52 PM(UTC)
will_massey00
hmmmmmmm I tried taking a few photos last night but they didn't come out too well. On further inspection, a couple of the other holes don't quite line up either. Curious!
I'll clean it up and take more pics this arvo.
Anyone any ideas?
This page was generated in 0.022 seconds.
