will_massey00 Offline
#1 Posted : Thursday, 17 May 2012 6:09:03 PM(UTC)
will_massey00
I have an issue with the bolt pattern on a 308 that I bought some years ago. It is supposed to be a Trimatic pattern so that I can fit a manual gearbox. The dowels and upper bolt holes line up but the bottom two are about 1/2 hole out. Has anyone known this issue before?
It obviously isn't a Turbo pattern as they are quite a lot different, and I have a couple of bellhousings and a trimatice geabox which all have the same issue, so it's not them.
Regards
Will
#2 Posted : Thursday, 17 May 2012 9:15:10 PM(UTC)
That sounds a bit odd. Does it look like someone has maybe filled, faced & re-drilled the lower holes ?
#3 Posted : Thursday, 17 May 2012 10:19:28 PM(UTC)
will_massey00
I don't think so. I will take a few pics tonight. I would understand if the holes were elongated but they aren't.
There are only two variants right. When I bought it, from Gazza's in Melbourne, they said it came out of a ute with a trimatic. The onl thing I can guess is that the bolts were never in there!!!
Weird
#4 Posted : Friday, 18 May 2012 6:12:52 PM(UTC)
will_massey00
hmmmmmmm I tried taking a few photos last night but they didn't come out too well. On further inspection, a couple of the other holes don't quite line up either. Curious!
I'll clean it up and take more pics this arvo.
Anyone any ideas?
