coupe Offline
#1 Posted : Thursday, 11 September 2014 6:59:54 PM(UTC)
coupe
Theres so many v8 powerglides out there how can I tell if its from a hk, I'm looking at one on the weekend and need to know, cheers
#2 Posted : Friday, 12 September 2014 6:00:29 AM(UTC)
When i'm near the couple I have i'll let you know what is on their plates. Both are from HK Broughams. HT 307 'glides will be the same as later HK ones too.
coupe Offline
#3 Posted : Friday, 12 September 2014 6:07:41 AM(UTC)
coupe
Cheers Byron, I'm looking at one Saturday morning and just want to make sure its the right one
bazza30555 Offline
#4 Posted : Saturday, 13 September 2014 6:01:14 AM(UTC)
bazza30555
Just had a look on mine but couldn't find anything, were do you find the numbers. Cheers Bazza
coupe Offline
#5 Posted : Saturday, 13 September 2014 6:57:44 AM(UTC)
coupe
Cheers Bazza, yeah I was hoping to know before the morning but I can go have a look and take some pics and see if I can find any numbers
#6 Posted : Saturday, 13 September 2014 5:49:57 PM(UTC)
I won't be able to look until later Saturday
coupe Offline
#7 Posted : Saturday, 13 September 2014 11:37:08 PM(UTC)
coupe
No probs Byron, I had a look and have some numbers from inside the bellhousing, ill post them soon, cheers
justgm Offline
#8 Posted : Sunday, 14 September 2014 12:02:45 AM(UTC)
justgm
Date code is stamped on the right hand vertical side of the oil pan . hope this helps Mark.
coupe Offline
#9 Posted : Sunday, 14 September 2014 6:29:40 AM(UTC)
coupe
Here's some numbers
Right hand vertical side of oil pan E8P11DL
Under 'POWERGLIDE' Pat 1959.1960
Extension housing 3863192
The small splined output shaft spins freely but the larger spline shaft won't turn by hand at all, is this the oil pump?
#10 Posted : Sunday, 14 September 2014 6:20:25 PM(UTC)
I couldn't find much on the easily accessible one here.
bazza30555 Offline
#11 Posted : Tuesday, 16 September 2014 7:14:29 AM(UTC)
bazza30555
I have looked all over mine and can't find any casting numbers,date codes or an Id number on the main case or extension housing. It hasn't got Powerglide cast into the side either.
