Theres so many v8 powerglides out there how can I tell if its from a hk, I'm looking at one on the weekend and need to know, cheers
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
When i'm near the couple I have i'll let you know what is on their plates. Both are from HK Broughams. HT 307 'glides will be the same as later HK ones too. |
Cheers Byron, I'm looking at one Saturday morning and just want to make sure its the right one
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Just had a look on mine but couldn't find anything, were do you find the numbers. Cheers Bazza
Cheers Bazza, yeah I was hoping to know before the morning but I can go have a look and take some pics and see if I can find any numbers
I won't be able to look until later Saturday |
No probs Byron, I had a look and have some numbers from inside the bellhousing, ill post them soon, cheers
Joined: 30/04/2005(UTC) Posts: 485  ![New Zealand New Zealand]() Was thanked: 16 time(s) in 15 post(s)
Date code is stamped on the right hand vertical side of the oil pan . hope this helps Mark. |
life is good in "Wine & Holden Marlborough " |
Here's some numbers Right hand vertical side of oil pan E8P11DL Under 'POWERGLIDE' Pat 1959.1960 Extension housing 3863192 The small splined output shaft spins freely but the larger spline shaft won't turn by hand at all, is this the oil pump?
I couldn't find much on the easily accessible one here. |
I have looked all over mine and can't find any casting numbers,date codes or an Id number on the main case or extension housing. It hasn't got Powerglide cast into the side either.
