#1 Posted : Thursday, 5 May 2005 2:25:38 AM(UTC)
I have a mate that is looking to change the column shift manual in his ute, to a floor shifter.
Does anyone have a 3 speed manual shifter out there that they are willing to part with?? In Adelaide would be good, but he will look anywhere.
#2 Posted : Friday, 6 May 2005 1:59:40 AM(UTC)
Many moons ago we used to make our own you only need a length of rod and a couple of bits of iron bar, can't remember exactly what we did but you end up with a reverse H pattern with 1st on the right up, I think. You can get it to go the conventional H pa
74HJLS Offline
#3 Posted : Friday, 6 May 2005 4:38:12 PM(UTC)
74HJLS
If you can get hold of an Opel 4speed shifter it can be used on a 3 speed.
Pete.
Pete.
#4 Posted : Sunday, 8 May 2005 3:18:46 AM(UTC)
Hi Guys.
I've never seen an Opel 4-speed shifter used on an M15 3-speed, too many differences I think.
The best conversion, is to fit an Aussie 4-speed (M20/21/22) extension housing & shifter, they bolt straight on. Then just block off reverse. Conn
Bluez Offline
#5 Posted : Sunday, 8 May 2005 4:19:08 AM(UTC)
Bluez
What ever happened to the old Speco shifts they made to suit the holden 3 Speed?..was an after market shifter but it did the job...we put one in a HR back in the mid 80's.
Jesse Jesse Jesse, you've not got a sense of humour!
#6 Posted : Sunday, 8 May 2005 4:54:51 AM(UTC)
There is a 3 speed Speco floor shift on Ebay ATM. It's for an EH, so don't know about compatability. It's in Adelaide also.
Cheers.
#7 Posted : Sunday, 8 May 2005 5:42:02 AM(UTC)
classic oz wreck Offline
#8 Posted : Sunday, 8 May 2005 6:27:20 AM(UTC)
classic oz wreck
nice link...
www.classicozwreck.com.au
#9 Posted : Sunday, 8 May 2005 7:20:04 AM(UTC)
Lucky day I have one from my HQ. I only had it on for 12 months before the box died after 500,000 km couldn't complain. I fitted a Supra 5 speed and kept it ever since. It is in excellent condition.
Contact me on [email protected] with a reasona
#10 Posted : Wednesday, 31 January 2007 2:57:17 AM(UTC)
i just put a 3 speed floor shift in my bedford motorhome hard to get try barsby wreckers marybrough queensland
hairy-dude Offline
#11 Posted : Wednesday, 31 January 2007 12:05:39 PM(UTC)
hairy-dude
I have had both a Speco shifter on a 3sp, and done the four-speed conversion on a 3 speed, and both worked well. The speco shifter comes up through the floor closer to the driver than the four-speed shifter. It did not bother me as I did not have a center
#12 Posted : Wednesday, 31 January 2007 9:22:57 PM(UTC)
Why stuff around? Just go out and buy an M20 or preferably M22 box secondhand for $150. A rebuild kit is about $80 if the box is OK. The bellhousing, clutch, tailshaft, rear mount, speedo cable etc are all the same. You'll have the 3 speed out and the 4 s
