I have a mate that is looking to change the column shift manual in his ute, to a floor shifter.
Does anyone have a 3 speed manual shifter out there that they are willing to part with?? In Adelaide would be good, but he will look anywhere.
Many moons ago we used to make our own you only need a length of rod and a couple of bits of iron bar, can't remember exactly what we did but you end up with a reverse H pattern with 1st on the right up, I think. You can get it to go the conventional H pa
Joined: 20/03/2005(UTC) Views messages in topic : 316
If you can get hold of an Opel 4speed shifter it can be used on a 3 speed. Cheers, Pete. |
Cheers, Pete. Old Holdens never die, they just go faster. |
Hi Guys.
I've never seen an Opel 4-speed shifter used on an M15 3-speed, too many differences I think.
The best conversion, is to fit an Aussie 4-speed (M20/21/22) extension housing & shifter, they bolt straight on. Then just block off reverse. Conn |
Joined: 1/03/2005(UTC) Posts: 241  ![Australia Australia]() Thanks: 3 times
What ever happened to the old Speco shifts they made to suit the holden 3 Speed?..was an after market shifter but it did the job...we put one in a HR back in the mid 80's. |
Jesse Jesse Jesse, you've not got a sense of humour! |
There is a 3 speed Speco floor shift on Ebay ATM. It's for an EH, so don't know about compatability. It's in Adelaide also.
Cheers.
Lucky day I have one from my HQ. I only had it on for 12 months before the box died after 500,000 km couldn't complain. I fitted a Supra 5 speed and kept it ever since. It is in excellent condition. Contact me on [email protected] with a reasona
i just put a 3 speed floor shift in my bedford motorhome hard to get try barsby wreckers marybrough queensland
I have had both a Speco shifter on a 3sp, and done the four-speed conversion on a 3 speed, and both worked well. The speco shifter comes up through the floor closer to the driver than the four-speed shifter. It did not bother me as I did not have a center
Why stuff around? Just go out and buy an M20 or preferably M22 box secondhand for $150. A rebuild kit is about $80 if the box is OK. The bellhousing, clutch, tailshaft, rear mount, speedo cable etc are all the same. You'll have the 3 speed out and the 4 s |
