HQ_SS_Andy Offline
#1 Posted : Tuesday, 21 June 2022 3:25:33 PM(UTC)
HQ_SS_Andy
Hi All.
I am wondering if the rocker arm pivot bolts in a 304 should be loctite'd in.
If not, what stops them from backing off ? There are no spring washers.
Also, torque spec is 24-32 Nm. Seems like a big range. Would it be best to just shoot for the middle (i.e. 28Nm) ?
Rgds,
Andrew.
8D11PCH2 Offline
#2 Posted : Tuesday, 21 June 2022 4:50:05 PM(UTC)
8D11PCH2
As per GMH service manuals just install them and torque them up to spec.
The rocker pivot bolt torque specs for Red & Blue 253 and 308 engines is 30nm - 38nm.
I always err towards the higher end of the torque spec range.
HQ_SS_Andy Offline
#3 Posted : Tuesday, 21 June 2022 11:39:06 PM(UTC)
HQ_SS_Andy
Thank you 8D11PCH2.
Rgds.
#4 Posted : Wednesday, 22 June 2022 7:26:31 AM(UTC)
I've never seen one work loose. I have however seen them broken.
Don't over-tighten them, they are only 5/16 UNC, easy to break.
Edited by user Wednesday, 22 June 2022 7:27:08 AM(UTC)  | Reason: Not specified
Smitty2 on 23/06/2022(UTC)
HQ_SS_Andy Offline
#5 Posted : Wednesday, 22 June 2022 1:07:25 PM(UTC)
HQ_SS_Andy
Thanks Dr. Terry.
#6 Posted : Thursday, 23 June 2022 9:06:57 AM(UTC)
Originally Posted by: HQ_SS_Andy Go to Quoted Post
Hi All.
Rgds,
Andrew.
ps.. don't forget the rocker arm pivots only go on one way too
(don't get this wrong, if you do they 'die' rather quickly)
HQ_SS_Andy on 23/06/2022(UTC)
