Fastlane
Holden Forums
Holden Technical Talk
304 V8 Rocker Arm Pivot Bolt Install
Joined: 22/08/2020(UTC) Posts: 49 ![Australia Australia]() Location: Sydney Thanks: 16 times Was thanked: 1 time(s) in 1 post(s)
Hi All. I am wondering if the rocker arm pivot bolts in a 304 should be loctite'd in. If not, what stops them from backing off ? There are no spring washers.
Also, torque spec is 24-32 Nm. Seems like a big range. Would it be best to just shoot for the middle (i.e. 28Nm) ?
Rgds, Andrew.
Joined: 11/09/2016(UTC) Posts: 234 ![Australia Australia]() Location: OZ Was thanked: 29 time(s) in 27 post(s)
As per GMH service manuals just install them and torque them up to spec. The rocker pivot bolt torque specs for Red & Blue 253 and 308 engines is 30nm - 38nm.
I always err towards the higher end of the torque spec range.
I've never seen one work loose. I have however seen them broken. Don't over-tighten them, they are only 5/16 UNC, easy to break. Dr Terry Edited by user Wednesday, 22 June 2022 7:27:08 AM(UTC)
| Reason: Not specified |
Joined: 6/07/2019(UTC) Posts: 469 ![Australia Australia]() Location: bayside Melbourne Thanks: 303 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: HQ_SS_Andy  Hi All. I am wondering if the rocker arm pivot bolts in a 304 should be loctite'd in. If not, what stops them from backing off ? There are no spring washers.
Rgds, Andrew. ps.. don't forget the rocker arm pivots only go on one way too (don't get this wrong, if you do they 'die' rather quickly) |
Fastlane
Holden Forums
